Rear passenger side wheel noise
  • Rear passenger side wheel noise
    It's a 'coin in a tin can noise'. Its quite noticeable when I am driving slowly and over bumps. At highway speed it's not as noticeable probably because of road or wind noise.
    When I press on the brakes the noise is gone. So may be the caliper is hitting the rim ?? I have 18" and some spacers on it and the tire protrude slightly beyond the wheel wells.
    What might it be?
    Re: Rear passenger side wheel noise
    Could be a shot wheel bearing. Jack that corner up and spin the wheel. Caliper hitting the rim should be fairly obvious.
    When a rear bearing on my Jetta went, I noticed the sound went away under some conditions like cornering.
    Jeff
      did you recently replace your brake pads or rotors? also have you checked all of the control arms for free-play?
        Fixed. Loose anti vibration clip.
