VAG code for instrument lights?
    Re: VAG code for instrument lights?
    I did the seatbelt and door charms on mine, as well as the tranny recode to hold first gear. Other than that there really isn't much to change...
    Just so you know though, with the 00032 recode you still don't have full control of first gear. The only time it really "holds" until redline is when you're about 3/4 throttle or more...it won't hold if you're slowing increasing through the rpm range.
    BTW, I'm an idiot...I can't check my coding as my ECU and TCU are both in a large cardboard box on the other side of the country right now. I am positive however, that the 00032 is the same one I did . Just do a search on AudiWorld for "00032 recode" and you'll be good to go.
    Kyle
    2000 Audi S4
      I think the dash lights are hardwired onto the head light switch arent they,
      I know mine only come on with the switch
      Eric..
        okay so my cluster lights are on regardless of headlight switch.. i dunno if you can disable it or not.. if it bugs you dim them during the day i guess..
