HID Lights, how bright is too bright??
  • HID Lights, how bright is too bright??
    Just wondering what the "legal" limit is in edmonton?? 6000k?? 8000k??
    Re: HID Lights, how bright is too bright??
    get 4300k and your set.. and please put them into projectors at least and not oem NA lights or you'll blind everyone out there
      The K rating is not how bright the lights are, but the color of the light. 4300k is natural HID and is that all factory HID systems are. Anything higher than that will be more blue/purple, but there will be less usable light. As Ryan said, 4300k is the way to go. If you really must have more color, don't go higher than 6000k, after that they become too blue to really be useful, especially on wet roads.
      Mike - 2011 A4 S-Line
        It's putting the HID light into a reg Halogen lens. It's the bad glare that makes them too bright. Like Ryan said, find a projector lens.
          Hids in stock reflector halogen lights = one of the few times I support vandalism.
          Geoff
            the HIDs will be going into my stock fog lights. probably 6000k pure white.
              I did hiid's in fogs. Works okay. I would def. go 4300k though its the brightest and its still blue.
                these are my options....
                3000K Yellow
                4500K OEM Whiteish Yellow
                6000k light purple
                8000k light blue
                6000k pure white
                Going with 6000k Pure White most likely...
                  It doesn't work like that! The number is the color, and 6000 is definately blue/purple! 8000 is useless it's so blue/purple.
                  Fogs are supposed to be yellow anyway.
                  Geoff
                    don't know too much about HIDs but according to the web site I might be purchasing from they say this..
                    Note that there are indeed two different colors of 6000k bulbs available from XenoFlo. Some companies' 6000k bulbs are a pure white color, others are a purpleish color. To give our customers the most choice, we offer both 6000k purple and 6000k pure white colors.
                    So than they are wrong??
                      4300k end of discussion
                        Yes. They probably have tinted blue glass, which may strip out some of the blue but makes it less bright. That's like buying a red light and then running it through a red filter.
                        "Our 6000k HID conversion kits use genuine Philips Ultinon bulbs and ballasts. While these bulbs will offer approx. 20% less light than the 4300k bulbs they will provide a more bluish/purpulish output."
                        http://www.autolamps-online.com/hido...colourtemp.htm
                        Geoff
                          i have to say, get whatever color you want to get. doesn't really matter how much light output it produces, since, as OP said, it's only for fog lights anyways. also 8000k will still be brighter than halogen lights.
                          having said that, my setup is 6000k. blueish white.
                          99 BMW e46 323i SOLD
                          08 MB W204 C300
                            At 8000k the light output will still be greater than halogens, but there will be less usable light on the road. With an 8k color temp the light will be quite blue which our eyes don't see as well. Blue light is also refected more easily, so on wet surfaces you will have very little light on the road, signifigantly less than with a 4300k or even halogens.
                              yeah. i understand what you are saying.
                              but, like OP said, it's only for fog lights. it doesn't really matter how much light output it produces. that's why i said, get whichever he wants to get.
                              his fog lights are rectangle shape and not projected, which it should be angled down low to not to hurt eyes on oncoming traffic. ending up not much usable lights anyways.
                              if it was for headlights, then for sure i would recommand him don't get anything above 6000k.
                              08 MB W204 C300
