Needs some room, all prices negotiable.
I will update the list as I stumble across more stuff – there is more way more.
I do have ton (maybe more) of BMW E36 parts
1.8T ECU with GIAC chip $275
1.8T DBW Throttle body - $50
Instrument cluster, complete and uncut 01 GTi harness with fuse box and steering column, accelerator pedal, b.o.
01 GTi black, heated, cloth seats with airbags $350
02M with starter (51kms) - make ma an offer
24V VR6 engine 51kms - broken oil pan and hole on side into coolant passage, comes complete as it can be with everything still on the motor, throttle body, both manifolds, dual down pipe with cat and 2 02 sensors, alternator, PS pump, injectors, fuel rail, plugs , all the sensors, coolant and vacuum hoses, cut harness gone
2x1.8 8V complete engines, ECU's, ignition modules - if anybody needs any parts just let me know i'm sure I have them
2x MKIV PS steering rack,
break boosters, master cylinders, abs pumps, interior parts
96 OEM Jetta hood with headlights $100
MKIV OEM struts, shocks, springs top mounts - two sets, low kms b.o.
1.8T OEM SMIC - cheap
MKIV - Patec lowering springs - $100
Installation available
