I have a few sets of these trick aluminum eurolocks for sale. They are made of anodized aluminum (won't corrode) and very light. These go over your existing wheel studs or bolts. Locking or unlocking the locks only require you to slide in the special key and twist. The key is small enough that you can fit it to your keyring so no more hunting around for a lost key if you need to swap rims.
*** If you use spacers for your wheels and longer bolts, then this is probably the best solution. All the bolt type wheel locks are too short to extend properly into the hubs, possibly making that joint a weak point. ***
All are brand new in sealed packaging (17mm bolts). I'll deliver to the next meet. $35
