Have about 10,000km on them. Looking for $350.
fs: VW OEM Bosch .205 Injectors
Re: fs: VW OEM Bosch .205 Injectors
Bump for Boyracer:
If someone already had the basic Upsolute chip for a 1.9 ALH Auto. and wanted to put in the .205's is there an upgrade chip? Any risk of harm (ie boost - turbo blowing) running this combination with/without upgrade chip?
Just curious, love the basic chip but could always use a little more umph.
no, there isn't. they have a stage II which is meant for larger injectors, but that makes your car a little slower. these things will net you 20hp and 40ft-lb, trust me, i have dyno numbers
basically they give you alot more power high end, normally tdi's run out of fuel about 3500rpm, with these things, it will pull hard to redline.2002 VW Golf GT TDI
Just curious, love the basic chip but could always use a little more umph.Name: Brent
