Time to get rid of the GLI, moving on with life. I've enjoyed it for many many years, with its ups and downs, will be sad to see it go.
Car
General Specs
2004.5 VW GLI
Recaro Seats
Aluminum Interior Trim
6 Speed Manual O2M Transmission
~160,000kms
Platinum Grey
$8,000
Engine
Gonzo Stage 2+ ECU Tune
4bar Fuel Pressure Regulator
Integrated Engineering FSI/TSI Coilpack Adapters
OEM FSI Coilpacks
034Motorsports Catch Can/PCV System
Forge 007 Diverter Valve
Eurojet Lower Boost Hardpipe
Pwrhaus SMIC with Custom Rock Guard
Excessive Amperage 200A Alternator (off car, needs rebuild)
Pwrhaus Turbo Inlet Pipe
Pwrhaus Throttlebody Hose
New South Performance Power Gasket
Vibra-Technics Motor Mounts (all 3)
Blox Racing 3” Velocity Stack
6” K&N Air Filter
Billet Injector Cups
42DD Aluminum Shifter Bushings
034Motorsport Shifter Bracket Bushings
General Engine Bay & Wiring Cleanup (SAI, Evap, N249 delete etc)
Suspension/Air
Airlift Slam XL Front Struts
Firestone 7076 Rear Sleeve Bags
Bilstein Rear Dampers
2.5 Gallon Aluminum Tank
3 Gallon Aluminum Tank
4 x Air Zenith OB2 Compressors
Accuair E-level Management with Touchpad
Safety Bleed Valve
Schrader Valve for Use of Air Tools
Kleinn99 Air Horns (hooked up to OEM horn location)
Wheels
18x8.5 1552 RML Snowflake Wheels with custom
powdercoat/polish
215/40/18 Nitto Neogen Tires
Trunk Setup
B-Quiet Ultimate Vibration Dampening & Mass Loaded Vinyl/Closed Cell Foam Sound Deadening
Air Circulation Fans (when compressors kick on)
Custom Rubber Trunk Liner for Daily Driving
Custom Vibration Isolation Compressor Frame
Interior
Air Zenith Digital Pressure Gauge with 42DD A-Pillar
Retrofitted Recaro Seats to Include Heating Elements
MK6 Scirocco R Steering Wheel
JVC KW-NT500HDT 6.1” DVD/Navi Head Unit
Hidden Compressor and Pressure Gauge Kill Switches
Zada-Tech Multi Gauge System (Fitted into OEM
Cluster Clock Location)
Exterior
Custom GLI Hood Bra
Retrofit Headlights (Acura TL Projectors, Osram Xenarc SVS HID Bulbs, Morimoto 5Five Ballasts, Dual Turn Signals, Volx Tuning Glass Lenses with 3M)
Shaved GLI Trunk
OEM Porsche Cayenne Backup Camera
OEM Orange Repeaters
Roof Racks (OEM)
Known Issues
Zadatech gauge not fully hooked up, no issues with it besides the fact that there is no boost gauge in the car (and has been fine, never had one in this car)
Paint is a bit meh on the car, front PS fender is the worst
Euroswitch PS headlight main is fused closed, need new switch to make main beams work (fuse is currently out)
I've taken the thermostat out because it's a summer car, I have one to put in but haven't done it yet
Partial Partout Section
If you see something on the list that you think you would like, shoot me a message. Price is by offer, so make one and we can discuss if it's fair.
The things that would have to all be "called" at once to move forward with a partout just due to the huge nature of the change and the available market for the vehicle would be
- Airride System
- Wheels
Other smaller items that could be "replaced" if you had a stock part would include:
- SMIC and piping
- Motor Mounts
- Steering Wheel (would need a leather 3 spoke in trade + $)
- Headlights
- DVD/Navi Head Unit
etc
Spare Parts
I've also hoarded a ton of spare parts over the years. Everything from a spare sunroof, windows, to replacements for window switches and regulators, etc.
These will all come with the car or can be purchased separately. Will update with more info if people desire
Car
General Specs
2004.5 VW GLI
Recaro Seats
~160,000kms
Platinum Grey
$8,000
Engine
OEM FSI Coilpacks
6” K&N Air Filter
Suspension/Air
Safety Bleed Valve
Wheels
powdercoat/polish
Trunk Setup
Interior
Exterior
Custom GLI Hood Bra
Shaved GLI Trunk
Roof Racks (OEM)
Known Issues
- Airride System
- Wheels
- SMIC and piping
- Motor Mounts
- Headlights
etc
Spare Parts
