Details
2001.5 Audi S4 B5
6spd.
Silver
226 000
18x8 replica rs4 style wheels with 235/40/18
Eibach front coils, st rear coils (with a spare set of st front coil overs)
APR 91-93 ECU tune with program switching from cruise control
APR Stealth Catback Exhaust
Piggy open downpipes
APR Snub Mount
Apikol Rear Diff Mount and Carrier Bushings
Stern Transmission mounts
Stern Motor Mounts
RS4 intercoolers
Hyperboost diverter valves.
Toy guy short shifter
Pioneer AVIC in dash stereo
Upgraded JBL speakers
Brand new fancy fat air leather steering wheel that is pretty much a flat bottom MK4 R32 wheel (for a comparison size/shape) but is with the OEM airbag
Maintenance:
three timing belts done. Most recent at 220k
Water pump and all coolant oring's replaced.
Replaced fan clutch
Upgraded 2.0t coil packs.
New spark plugs bk7re
New fuel filter and fuel lines
New front abs sensor
Valve cover gaskets replaced and all those other little bits
Updated PCV and spider hose setup.
New alternator and AC compressor
Oil's been changed every 5-6k with rotella t6. Most recently at 225 000
Door vacuum pump replaced
NO dents or major rust on the car but has some clear coat issues and rock chips up front
One front fender has some chipped paint where wheels rubbed/plasti-dip was removed so fender needs to be replaced probably at some point (fenders on b5 are cheap 75 bucks)
needs a new airbag controller
only code this car ever throws is for the one rear 02 sensor because of the downpipes.
Asking 5500 for Eurodrivers members
