Hi, Im sure alot of people have seen this on kijiji, thought I would post it here as i have dropped the price.
Open to reasonable offers, want this to go to a good home!
2001 Audi TT 225hp 1.8t w/ 6speed manual 252,000km
Vehicle is very well maintained with only new OEM or better parts, recent items include:
-haldex pump/fluid
-all maintenance done (driveline fluids, filters, spark plugs, etc.)
-timing belt/water pump
-accessory belt and tensioner
-valve cover gasket/cam tensioner seals
-coolant flange/ temp sensor
-instrument cluster refurbished at BBA
-turn signal arm replaced
-emergency flasher relay replaced
-heater fan replaced
-both door latches replaced
-battery distribution block replaced
-R8 ignition coils/integrated engineering adapter plates
-turbosmart diverter valve
-airbag control module (approx. $800)
-ksport coilover suspension w/ 034 track density front upper mounts
-front and rear swaybar links
-rear brakes
-ECS rear lower adjustable control arms
-3" milltek non-resonated cat back exhaust, titanium tips (Less than year old, perfect condition)
-034 Motorsport street density engine/trans mounts
-polyurethane dogbone mount bushings
-complete tie rods
-front ball joints
-HD front control arm bushings
-recent oem clutch/flywheel
-aluminum integrated engineering shifter bracket bushings
-integrated engineering SAI block off plate, SAI deleted
-factory polished fat five forged wheels with nokian wr all season tires.
-'QUATTRO' mud flaps
-TT 3.2 extended rear spoiler
-TT 3.2 front bumper (not pictured)
Original color is silver, has been vinyl wrapped teal green.
PRICE:$8500
-haldex pump/fluid
-rear brakes
-complete tie rods
-front ball joints
PRICE:$8500
