Well I've decided to post again. Hopefully I can move this car, lost all interest in it and have to many other cars to deal with.
2001 Audi S4. Give me $6500 and drive it away.
The good:
Billet rs6 48mm turbos
SRM Inlets
Samco Hoses
Forge 007 Bypass valves
JHM fmic
52lbs injectors
90mm MAF
SRM RS6 Downpipes
SRM exhaust
JHM B7 RS6 stage 4 clutch/flywheel
034 race mounts
JHM trio shifter
034 rear sway bar
ST coilovers
B6 S4 front brakes
Kosei K1 TS wheels
New timing belt, water pump, n75 valve, aux pump delete, etc..
Port matched intake manifold
I know there is more that I am missing. Lots of new parts, lots of good parts. All performance parts have less then 2000kms on it.
The bad.
Needs a 2nd gear synchro, will not shift into second unless the car is shut off. Stupid pos o1e.
Needs front bumper. Destroyed 2 so missing one.
Paint is a bit rough, not terrible but not great either. Santorin blue.
I can message people pictures of the part when the were off the car or being installed.
Lots of work, done to this thing. I need it gone.
The good:
SRM Inlets
Samco Hoses
JHM fmic
52lbs injectors
90mm MAF
SRM RS6 Downpipes
SRM exhaust
034 race mounts
JHM trio shifter
034 rear sway bar
ST coilovers
B6 S4 front brakes
Kosei K1 TS wheels
The bad.
