http://www.kijiji.ca/v-cars-trucks/calgary/1060053310
1999 BMW M3 Coupe 5sp
Hellrot on Dove
149500 km
Amazing car, done right with lots of thought put into the modifications. Must be seen and driven to be appreciated. Very clean and well taken care of (see below).
More pictures to follow this evening.
$14,000
- VF supercharger kit @ 6psi - never dyno'd but estimated to make between 320 and 350 hp.
- ARP head studs
- M50 manifold with Turner adapter plate
- Straight pipe exhaust (twin stainless with H pipe)
- AA Signature Gen 3 muffler
- SAP delete
- Rear O2 delete
- CCV delete to VMS catch can
- Rtabs, fcabs, carriers, mounts
- Bilstein sports, Eibach pro-kit
- LTW xbrace
- E46 330xi spring pads
- Brembo blanks / Axxis pads / ATE super blue
- Turner stainless lines
- Rebuilt calipers
- Radar hardwire
- Momo Monte Carlo wheel
- ZHP knob
- Depo glass lights with VVME 55w HID 4300k
- Clear sidemarkers
- Blackout grilles
- Euro console
- AEM UEGO boost/vac gauge and H-pipe mounted AFR
- Fog blockoff plates
- Motion Motorsport aluminum skid plate
Wheels
- Turner stud conversion kit
- Turner 12.5mm front 10mm rear spacers for winter
- 4x8.5" contours, 225/45 LM60 Blizzaks
- 4x8.5" APEX Arc-8 245/40 Hankook Ventus V12
Maintenance history
140k - Inspection II
------ - Clutch (OEM)
------ - All belts/pulleys
141k - Central locking system and brake circuit fixes
------ - Power steering hoses and reservoir
------ - Complete brake job with rotors, stainless lines and caliper rebuilds
------ - Complete suspension swap with mounts, fcab, rtab, spring pads
143k - VANOS rings and spacer plus all VANOS parts, lines, gaskets
------ - ABS hydro pump
------ - Brake booster travel sensor
------ - Various relays
144k - Supercharger install
------ - Spark plugs
------ - New front O2 sensors
------ - Fuel filter
145k - Motor mounts
------ - Tranny mounts
------ - Wheel bearings
146k - Elring head gasket and all supporting gaskets
------ - ICV, temp sensor, camshaft position sensor, lines
------ - M50 manifold and Turner adapter installed
------ - CCV delete (VMS catch can with filter)
------ - Fan clutch
------ - Cooling system (new radiator, Stewart HP WP, tsat/housing, expansion tank, hoses)
Additional parts included (at the right offer price)
- Clutch slave and master cylinders with stainless line
- Guibo and CSB
Hellrot on Dove
149500 km
$14,000
- ARP head studs
- SAP delete
- Rear O2 delete
- LTW xbrace
- Rebuilt calipers
- Radar hardwire
- ZHP knob
- Clear sidemarkers
- Blackout grilles
- Euro console
Wheels
Maintenance history
145k - Motor mounts
------ - Fan clutch
- Guibo and CSB
