Hey guys,
So it's time to do some spring cleaning. There's a long list of stuff for sale. Parts are used unless otherwise stated. No guarantee on parts, sold "as is". No pics available, unless otherwise stated. First come, first served. Post in this thread if you want something, or if you want to come and look at anything. "I'll take it" reserves the part, cash is king, EMT is queen. I'm not going to ship individual parts, but if you want several parts I may be willing to ship. Local pickup preferred. I will update availability as often as I'm able to.
The list:
B5 S4
- 1 used FW - surface rust. Great for a resurface - $30
- 2 used OEM PP - $15 each
- 1 new VAST PP - has problem, good project - $20
- 2 worn clutch disks - can use as core - $10 each
- 3 sets OEM turbo heat shields - $10 per set
- 1 set OEM IC's with samco hoses - $75 for the pair
- 1 set OEM IC shrouds - $20 for the set
- 1 OEM 8D0 407 271 AR driver's side front axle - requires new inner boot and possibly inner CV joint - $30
- 1 coolant reservoir - no known leaks - $10
- 2 used TB and 1 used Acc belts - $5 each
- 1 set axle heat shields - $10 for the set
- 1 set AC condenser shrouds - $5 for the set
- 1 K03 turbo - passenger side - some play in compressor shaft, but not excessive - good shape - $50
- 1 set used rear O2 sensors - $20
- 1 set used front O2's - $20
- 1 K&N filter kit - $50
- 3 accordion hose - $15 each
- 1 OEM front grill - '00 - $35
- 2 OEM heater vent inserts - $15 each
- 2 OEM MAF sensor housing - $10 each
- 1 heater core hose sheath - $5
- 1 intake air duct - $10
- 2 PS fluid reservoir covers - $10 each
- 3 transmission shifter linkage ball assy's w/ wedge - $15 each
- 1 TB tensioner clock lever - $5
- 1 heater vent flap - $5
- 1 OEM fuel pump basket - $45
- 1 full set engine covers (2 sets side covers) - $10 per cover or $30 for a full set
- 1 OEM airbox - $35
- 3 N75 valve - believed to function normally, cannot guarantee - $15 each
- 1 OEM silver bumper grill insert, pass side - $20
- 1 OEM bumper headlight washer nozzle cover - $5
- 1 set OEM Y pipe boots - no known leaks - $10 for the set
- 1 Auto shifter assy foam cover plate - $10
- 1 auto shifter lever and clips - $15
- 1 OEM pancake valve - $10
- 1 bag of new random OEM clips, one-way valves, etc - $20 for the bag
- 1 set OEM rear struts - $50 for the set
- 1 set front Alko struts - $50 for the set
- 1 full set springs - $75 for the set
- assorted OEM intake hoses - $45 for the bag
- 1 set OEM injectors - $100 for the set
- 1 new JHM delrin stabilizer bushing, '01 - $25
- 1 Acc belt tensioner - $15
- OEM airbox with AWE S-Flo filter - $50
- 1 set K03 turbos - working fine in last know condition, need to be cleaned (dust, etc) - $100 for the set
- 2 sets OEM inlet pipes - $25 per set
- 1 bumper headlight washer hose assy - $10
- 10 copper turbo banjo washers, sold as a set only - $5 for all of them
- 2 OEM MAF housing and sensor - $35 each
- 2 new cam shaft oil seals and 2 new plugs - $10 for all
- (2) 4Bar FPR - $20 each
- 5 OEM injectors - $70 for the set
- 1 kit touch up paint markers - light silver - $10
- new FCP outer TRE's (pair) - $100 for the pair
- 1 wiper arm - unknown side - $15
- 1 OEM shift knob - $25
- RS4 new rubber accordion hose collar - $10
- K03 turbo coolant pipe - $10
- K03 oil lines - $10 for the lot
- new brake light switch - $5
- (3) 710A DV - $10 each
- new autobahn88 F hose - $15
- OEM F hose - $8
- brass MBC with silicone hoses and brass fittings - $35
- plastic T fittings with hose for N75 or MBC - $10
- clutch fan delete cover plate - $10
- ignition switch - $10
- PS reservoir cap/dip stick - $10
- 2 clutch alignment tools - $8 each
'06 Jetta Wagon TDi
- transmission with hole in housing- good for most of the internals! - $40
- 1 coolant reservoir cap - $5
'91 VW Golf and '92 VW GTi 2.0L 16v
- 2 new front CV boot kits - $15 each
- 6 new seat rail clips - $10 for all of them
- new ABD front strut bar - $75
- 1 new single round headlight support assy w/ badgeless grill and e-code headlights - $100
- 1 new single round badgeless grill - $40
- new Dynomax 2.5" trombone shaped exhaust pipes - Free with muffler
- new Magnaflow muffler - 14226 - http://mudflaps.com/i-6713458-magnaf...l-muffler.html - $75
- 2 new K&N recharger kits - $10 each
- 4 MANN oil filters- W719/5 - $20 for all
- unopened exhaust joint and crack sealant - $5
- new Empi adv oil cooler 72 plate - 00-9265-0 - $103.50 retail - $60
- new Bosch premium plug wire set - 09273 - $30
- random used valves, ignition cap, etc - free
- 2 new Vibrant silicone boots - $10 for the pair
- new Forge DV - FMCL007P - $85
- unknown boot - free
- throttle body - ABE - $20
- new INA lifters (2 complete packages) - F-46516.30 TSTH - $90
- new FK alum wheel spacers - FK00920BZ - $85
- new "Zenon" H4 bulbs- 60/55W - $10 for the pair
- headlight connector harnesses - free
- lug bolts - free
- random used parts - free
'86 Toyota 4Runner
- 1 set of 4 new 22RE Doctor Injector shop injectors - $150 for the set
- 1 new clutch kit with PP, FW, and clutch disk - $100 for the kit
- 1 new exhaust mani gasket - $20
- 1 rear wiper motor cover - $10
- 1 rear view mirror - $10
- 1 rear wiper motor assy - $20
- 1 MAF sensor with top half of air box - $50
- 1 rear shock - free
- 1 set lug nuts - $15
- AISIN Hub cover parts - $20
- coil with igniter - $20
'03 Subaru Impreza
- 1 rear wiper motor assy with wiper arm - $20
'90 4Runner
- 1 set sealed beam headlights - $10
- 1 ignition switch with key - $15
The list:
B5 S4
- OEM F hose - $8
'06 Jetta Wagon TDi
- lug bolts - free
'86 Toyota 4Runner
'03 Subaru Impreza
'90 4Runner
