FS: Lots of B5 Audi A4 1.8t parts! Forge DV, APR ECU, TCU, PCV, RS4 wheels, etc.
  • FS: Lots of B5 Audi A4 1.8t parts! Forge DV, APR ECU, TCU, PCV, RS4 wheels, etc.
    B4 A4 Parts for sale:
    -Used S4 front grill dark gray/granite colour including Chrome Audi logo rings and trim, does not include S4 logo or `Quattro' badge. Some marks from rocks, etc. but overall in very good condition. 8D0853651S $75.00
    -New Optimal brand rear wheel bearing, with Axle bolt, replaces: 8D0598625A Optimal part # 100093 - $20
    -Rear caliper piston boot, new, single boot. - Free
    -Osram Instrument cluster bulbs, 4A0919040C, $1 each, 10 available
    -New PCV breather system repair kit (Does not include 034-129-101-B "puck" PCV valve)
    Kit includes:
    (4) 058-905-291 check valve
    (1) N-904-673-01 breather tube seal
    (1) 058-103-213 breather tube
    (1) 06A-103-247 bleeder valve housing
    (1) 035-103-245-A bleeder valve
    (1) 058-133-753B Purge Valve
    Asking $150, parts retail for well over $250.00!
    Oil seals leaking? Could be a plugged PCV system. These are the parts needed for the DIY replacement of the 1.8t PCV system (Message me for link to DIY) DIY is for a 1.8t Passat but mostly applies to the 1.8t A4 as well, with the addition of the 058-133-753B Purge Valve for the A4
    -Heavy Duty Lemforder updated all metal "B" version Tie Rod End, part # 8E0419811B $50 (Do yourself a favor and get high quality TRE's, you'll thank me later!!)
    -Corteco Snub mount $5
    -Used Driver's side heated mirror glass, a little discoloration along bottom edge but still ok to use. Better than a broken one!! Aspheric glass, heated. $10
    -Used Passenger side `Stubby' Mirror glass, some staining behind glass, ok to use if in a pinch. $5
    -1997 A4 Heater/climate controls, work perfectly but one LCD screen is damaged, can still read display but display is a bit messed up. $25
    -'97 A4 1.8t Quattro Automatic Transmission Control Module / TCM $75
    -'97 A4 1.8t Quattro Automatic Transmission non-tiptronic shifter and linkage. Includes shift knob and plastic cover. $50
    Willing to ship but buyer pays shipping. Will try to find cheapest shipping option possible and happy to try and combine a bunch of things into one shipment.
    If you want pics of something, just ask and I can email them.
    2006 Audi A4 Avant, 2.0tQ, 6spd, Dolphin Gray
    Re: FS: Lots of B5 Audi A4 1.8t parts! Forge DV, APR ECU, TCU, PCV, RS4 wheels, etc.
    Headlights are sold.
      Bunch of stuff has sold, above list is up to date with everything still available.
