Both are brand new and have never been used. I'm selling because I've changed my layout design.
Compressor specs:
- Viair 380cc
- 200 PSI / 1.34 CFM
- 12-Volt
- Permanent Magnetic Motor
- Duty Cycle: 100% @ 100 PSI
- Max. Working Pressure: 200 PSI
- Max. Amp Draw: 23 Amps
Parts Included:
- Check Valve
- Vibration Isolators
- Mounting Hardware
- Stainless Steel Braided Leader Hose
- Remote Mount Air Filter Assembly
- (2) Replacement Air Filter Elements
- Dimensions: 9"L x 4"W x 6.75"H
- Net Weight: 8.75 lbs.
380C is a truly-rated continuous duty, 12-volt, 200 PSI compressor. It is capable of filling a 5-gallon tank from 165 PSI to 200 PSI in 3 1/2 minutes consistently, while never pulling more than 18 amps of power (@ 13.8 volts). Features include a standard 1/4” stainless steel braided leader hose with 1/4” NPT inline check valve and insulated wiring.
Price $200.
Accuair aluminum 3 gallon tank
Specs
- 3 Gallon Capacity
- Rated for 150 PSI
- 4 x 1/4" ports (1 on the back, 1 on each end, and 1 on the bottom)
- 2 x 3/8" ports (1 on each end)
- 1 x 1/8" port (on the back)
- 17.75" L x 7" H
- 18.5" L (port to port)
- painted black from accuair which is a $50. option
($145. new) - Price $120.
Compressor specs:
- Viair 380cc
- 12-Volt
Parts Included:
- Check Valve
- Mounting Hardware
Price $200.
Specs
- 3 Gallon Capacity
- Rated for 150 PSI
- 17.75" L x 7" H
