I have to clear out some boxes out of the basement to make room for other projects. Lots of Parts, rims, etc.
Part | Asking | Picture |
BBSRX 16x7 5-100 43offset BG Goodrich T/A KDW 2 225/45-16 |
$1250 | ![]() ![]() |
B5 S4 Avus wheels 17x7.5 and Nokian WR tires 225/45 | Sold | ![]() ![]() |
B5 S4 ECS two piece rotors with red-stuff pads both with about 90% left (will fit other applications) | $350 | ![]() ![]() |
B5 S4 front calipers with SS brake lines, clearanced to fit most wheels will fit other applications | $120 | ![]() |
OEM Airbox Darintake Mod with dry K&N filter | $100 | ![]() |
Ko3 turbos 80k km were strong till upgraded | Gone | ![]() |
Frankenturbo f4h-bt CHRAs 5k km, good shape just upgraded to the F21s | Gone | ![]() |
b5 Headlights with clear corners only spent 2 years in calgary so they are in decent shape | Gone | ![]() |
B5 S4 injectors | $50 | ![]() |
B5 S4 intercoolers | $100 | ![]() |
B5 S4 mafs - one Bosch housing and sensor, 2 Hitachi housings one stock intake tube | $25 each | ![]() |
B5 S4 front mesh. Melted off (not cut off) just like they are installed at the factory so they will go back in easily | $50 | ![]() |
B5 S4 rear sway bar will fit other applications | $50 | ![]() |
OEM coil packs and ICMs | Sold | ![]() |
Trans and engine mounts 80k and 40k | $30 a pair engine Mounts gone | ![]() |
rear M3 style spoiler | Sold | ![]() |
POS 90mm intake hardly used | $75 | ![]() |
B5 S4 fuel pump 80k km | Sold | ![]() |
B5 S4 front grill | $50 | ![]() |
Black Turbosmart Boost Tee MBC new never installed went with PPD boost Addon |
$60 | ![]() |
