This is the micro switch that is screwing your door ajar lights, if you can't lock your car properly or you door sensor is going you need a new one, I fixed mine with these genuine Shanghai-VW micro switches, they work on B5 Passat, MK4 Jetta and Golf. The switch come with a clamping thing and heat shrink tube too so you don't need to solder, just cut off the old switch and clamp the new one on. $10 each, I have 2 for drivers side and 2 for passenger side.
VW door switches
Re: VW door switches
Only two passengers side left. The switch already come with the seatingCurrent Fleet
#ProjectICreate Jetta GLI32
2001 Cobra #88/3786
1989 Jetta Trophy 1 of 500
Motorsport Engineer
Originally posted by CGDoig View PostThis is a good item. I fixed mine with a $2.50 micro switch from the source. But it required a lot of cursing and trial and error to get it in the right position.Stefan
Still have these?Stefan
3 passenger side in stock(fits passat, jetta, bettle, golf and TT MK1), also have one set of TT MK1 aluminum pedals for AT MK4 B5 cars.Current Fleet
2001 Cobra #88/3786
Motorsport Engineer
damn I need a drivers I think...my only issue is the drivers door doesnt lock with the fob..it unlocks it fine..and the car arms but that drivers pin just wont go down...you can even hear it trying...as a matter of fact every once in a blue moon it works. Frustrating! I've taken the door panel off and watched it could'nt figure it out. Wonder if this is the fix I need?Last edited by jaysleeves; 07-04-2013, 09:15 PM.Bagged 2004 Jetta GLS 1.8T Stage 2 Unitronic, 2016 Tiguan R-Line , S13 SR20DET, Mk2 VR6 Project, 2011 Dodge Ram 1500
Originally posted by jaysleeves View Postdamn I need a drivers I think...my only issue is the drivers door doesnt lock with the fob..it unlocks it fine..and the car arms but that drivers pin just wont go down...you can even hear it trying...as a matter of fact every once in a blue moon it works. Frustrating! I've taken the door panel off and watched it could'nt figure it out. Wonder if this is the fix I need?Current Fleet
2001 Cobra #88/3786
Motorsport Engineer
There are solder issues with some locks too. Mine generates a fault code too.Stefan
Originally posted by jaysleeves View Postdamn I need a drivers I think...my only issue is the drivers door doesnt lock with the fob..it unlocks it fine..and the car arms but that drivers pin just wont go down...you can even hear it trying...as a matter of fact every once in a blue moon it works. Frustrating! I've taken the door panel off and watched it could'nt figure it out. Wonder if this is the fix I need?Name: Brent
Originally posted by stefan View PostThere are solder issues with some locks too. Mine generates a fault code too.Current Fleet
2001 Cobra #88/3786
Motorsport Engineer
