I have some MKIV stuff laying around that I need to get rid of. (Need to get car finished up, and tax return isn't as good as I had expected)
-FK 5mm Spacers (20$)
-PG GLI Rear Rubstrip with the chrome molding, mediocre condtion (will need repainting) (20$)
-Rear valence without cut out (20$)
-Stock GLI catback, will need to be welded up due to being cut in half (60$) SOLD
-Stock downpipe, flex pipe is broken but cat and o2 are still good (10$) C/S
-SAI pump (10$)
-Stock airbox (10$)
-Steel coolant/evap hardline (by fuel rail) (C/S$)
-Used GLI brakes rotors (free)
The following stuff will be available in two to three weeks (when the snow should be out of the way) :
-OEM 4motion front valence color matched platinum grey (100$) C/S
-10 extended lugs for 8mm-10mm spacers (20$) (willing to trade my 8mm spacers for 10 or 12mm ones)
-10 extended lugs for 15mm spacers (30$)
Not really wanting to sell but if someone wants I'll seriously consider:
-18" BBS RC's 225/40/18 GoodYear Eagle tires. One wheel also has a slight bend in it, hardly visible does not leak any air, but does make a slight noise at speeds below 15-20. No curb rashes, but some small scratches. 500 OBO, I will post pictures as soon as I can. SOLD
-Hotchkiss Under axle sway bar 200$ FIRM
Wheels:
Additional photos
^This is the bent wheel, the section in question is near the top.
And the GLI suspension components:
Pretty much everything else is self explanatory, but feel free to inquire for additional photos.
Most of the prices are reasonable in my mind, but most things are OBO.
You can PM me or Text me at 403-852-6529
-SAI pump (10$)
-Stock airbox (10$)
Wheels:
Additional photos
