I only run 7mm front and 10mm rear, the rears sit pretty much flush with the fender, fronts have enough clearence for steering.A wider wheel will sit out farther than a narrower wheel if the offset is the same.
I know the allroad will be a bit different, but you're welcome to come test fit them if you're interested.
