Front seats from 2012 Golf R
Re: Front seats from 2012 Golf R
Originally posted by bart View Postdoes the golf r have an air bag off switch in the glove box?
If so, explain the problem you are having as I have become a fountain of useless knowledge on this subject of late!Nick
I love hatchbacks
tt has passenger occupant sensor, it detects if someone is sitting in the seat or not, extra fudging is required to get it to work, the yellow airbag resistors were not enough2002 VW Golf GT TDI
Originally posted by bart View Posttt has passenger occupant sensor, it detects if someone is sitting in the seat or not, extra fudging is required to get it to work, the yellow airbag resistors were not enoughNick
I love hatchbacks
so did you do the transplant? i bought an extra OCS mat, yes i had to move the seatbelt too, however i still get a seatbelt light for the driver side as i did not move that seatbelt buckle over
later i had some probs with the OCS mat as the airbag off light started coming on meaning no passenger airbag, in a newer vagcom update i found a way to disable the mat completely so the airbag is on all the time no matter what, eliminating the need for the mat, it wasnt documented before how to do this, the seatbelt thing can probably be defeated too with some coding but the possible values arent documented, i was trying to find someone in europe with these seats to give me their coding so far no luck2002 VW Golf GT TDI
I didn't do a transplant because the Canadian R has no OCS on the passenger side. Just resistors and a vag com to clear the codes are all I need. My resistors are in but I'm waiting for an opportunity to do Vag Com.
It's strange that you get a seatbelt light on the drivers side because your drivers side Recaro should be fully functional with OCS and correct seatbelt connector wired in. Are you sure there isn't something wrong with the harness on the drivers side? Also, I'm assuming you've used OEM seats..Nick
I love hatchbacks
This may sound weird but can I sit in your car?
Originally posted by jacktown View PostI didn't do a transplant because the Canadian R has no OCS on the passenger side. Just resistors and a vag com to clear the codes are all I need. My resistors are in but I'm waiting for an opportunity to do Vag Com.
It's strange that you get a seatbelt light on the drivers side because your drivers side Recaro should be fully functional with OCS and correct seatbelt connector wired in. Are you sure there isn't something wrong with the harness on the drivers side? Also, I'm assuming you've used OEM seats..2002 VW Golf GT TDI
