I am going to post the original fs add from when I bought it aside from what I have done. Since I have owned it I have added:
- Bagyard bomber front struts, airride rear bags with bilstein sport shocks running on autopilot v2 managment ( have original suspension, put original back on and sell this if you want to make money back. Nothing cut or drilled with install can be returned to normal in a few hours )
- 215/40/18 continental DWS tires ( maybe 500kms on them )
- kerma TDI full 3" exhaust...no muffler no cat ( have a cat in storage I can include )... It isnt loud until the vnt opens then it sounds mean
- Front and rear brakes ( cross drilled and slotted ) with hawks low dust pads
- Have a oem headlight aiming dimmer switch and harness to install
- Have enough vw specific synthetic oil for another 1.5 oil changes. And filter.
- I am missing some things but will add more as I can think of it
Now for the original add which sums up the car better than I can:
Mileage 228,XXX KM - current as of Aug 30 2012
'04 Jetta Wagon GLS with BEW engine
Engine/Performance
Malone Tune
R32 Snorkle, etc to lower air box
ARL (PD150):
Air box top
TIP
Turbo
FMIC/RAD/AC Condensor
EGR/ASV
Intake
Injectors
Valve Cover
Engine wiring harness (moved MAP sensor wiring and added oil sensor)
Euro 02M 6 speed transmission (FMH)
GLI Brakes all around
ESP Upgrade with 4motion ABS controller (from R32)
TT Control arm bushings Front
GLI rear beam with bigger anti-roll bar (biggest OE avail)
Seat rear beam bushings
GLI Springs and shocks/struts
GLI BBS RC wheels
Goodyear Eagle F1 Assymetric tires (225/40R18)
Exterior
GLI Front lower spoiler
GLI Side skirts
Black grill
OE Headlight washer
OE HIDs (with 3M vinyl covers) and OE auto-leveling set up
Tri-Tone air horns hooked up to FUNK and GAS switch
Converted to Euro Shorty rear bumper
Rear Park-Distance sensors
European "Ocean" taillights
NO SUNROOF
Euro front rub strip (not drilled)
Interior
European Leather Recaros
R32 Dash
Full-FIS cluster with custom (OE) foils
MKVI MFSW which works!
Funk/Gas switches in lower trim panel
Climatronic
Euro Nav ("G") w/ proper triplex roof antenna
Euro TMC with PROPER MOUNT
Homelink Visor (properly wired so it's only powered with ignition)
GLI/337/20th/R32 Aluminum trim kit
Euro DSP Amplifier (Harman/Becker) with matching speakers
Pre-wired for CAN enabled phone unit (mic in headliner, etc)
W8 console
iPod adapter in glovebox
Electric FOLDING exterior mirrors (stubby on right, asymmetric on the left)
Autodimming Interior mirror
European rear net partition
Extras
The car is wired up for a trailer (euro 13 pin)
Car is wired to 4motion but I never got around to the conversion (there is currently a haldex unit plugged in sitting in the trunk)
I can provide the purchaser with a ton of stock parts and other spare parts if they'd like. I don't have everything that came stock on the car, but I have a bunch.
ALL PHOTOS HERE ------ Untitled | Flickr - Photo Sharing!
Original F/S Add Here http://forums.tdiclub.com/showthread.php?t=347832
The car is unreal, love it so much. But since we moved back to Calgary, my fiancee has been hired on with the CBE as a substitute teacher and needs a car... I cant afford to buy her one so this is the easiest way...unless I add more onto my line of credit
I am taking a loss. I did not barter with the original seller because I know what this car is.... I have added near 5k worth of stuff in the last few months.
Engine as dyno'd at roughly 180hp and 300ftlbs at the wheels before I put the 3" on. Much better now.
I am asking 15,500$.
Dont like the price? Keep it to yourself. I may be interested in trades plus cash, I want a MK4 golf for her around the 5-6k range + cash on your end
Engine/Performance
Malone Tune
ARL (PD150):
Air box top
TIP
Turbo
EGR/ASV
Intake
Injectors
Valve Cover
GLI BBS RC wheels
Exterior
GLI Side skirts
Black grill
OE Headlight washer
NO SUNROOF
Interior
R32 Dash
Climatronic
W8 console
Extras
