Engine: 2.8L 12V Head and Block (assembled together)
Cylinder Head Details: Gasket Matched Intake and Exhaust ported cylinder head and dipped while dissassembled to clean. Raised compression using a MKIV VR6 headgasket which is thinner(a common modification for increased HP). A pair of 268 profile intake and exhaust camshafts also for incresed horsepower.
Engine block Details:Stock as it uses forged internals from Volkswagen, but stripped, cleaned and painted in a rich red color. Installed a new timing chain set including guides and tensioner.
price:$1200.00 o.b.o with limited warranty and will deliver within the city. Price increases if delivering outside the city depending on distance.
Contact:Mike at 403-966-3574 or can leave a PM on this forum
![](http://img189.imageshack.us/img189/3118/dsc00144oj.jpg)
By projectvr6 at 2010-02-12
Complete Engine Replacement Kit not included
Price: $130.00
![](http://img525.imageshack.us/img525/1072/12152010097.jpg)
By projectvr6 at 2010-12-15
In Picture and may be purchased individually;
Flywheel bolts -Free
Pressure plate bolts -Free
Water/Coolant Distribution Pipe a.k.a. "Crackpipe" - $15.00
Oil Cooler seals (x2) - $4.00
Oil Pan Gasket - $25.00
Intake Manifold Gaskets (upper and lower) - $20.00
Exhaust Manifold Gaskets (X2) - $30.00
Downpipe Gasket - $2.00
Throttle body Gasket - $5.00
Valvecover Gasket - $17.00
Clutch Throw-out bearing - $30.00
Fuel Filter - $15.00
*ALL ITEMS ARE BRAND NEW UNOPENED IN ORIGINAL PACKAGING*
Price: $130.00
