As the title says, I have a 2003 GTI 1.8T for sale. Car has 175xxx km's. ALL Highway KM's. I drive from airdrie to south calgary everyday for work. WILL NOT PART OUT!!!
Motor:
KO4-001 Turbo
Eurojet Turbo Inlet Pipe
Eurojet throttle body hose
Eurojet boost hoses
Eurojet SMIC with round pipe in spot of pancake pipe
Forge Splitter Valve with custom machined Bosche valve adapter
AutoTech CAI
ACT 6 puck clutch with heavy duty springs and 7lb flywheel, shock proof gear oil
2.5 Downpipe to custom machined and fitted high flow cat, no resonator, straight back to dual exit magnaflow muffler. (people say its one of the best sounding MK4's they've heard)
APR software
ECS N75 Race Valve
Car spikes at 20lbs and hold 19-18psi all day long
New alternator last year
Timing belt, water pump, and tensioner were done at 110xxx
Chassis:
New 2011 FK Silverline X Plus coilovers with high heat shock oil and titanuim cylinders
Front sway bar deleted
Rear cups machined thinner to sit lower
Hand Built DZ Exlusivs from Germany. These wheels were hand made to be 17x10.5 rear and 17x8.5 front ET 35 Rear ET 25 front.
15mm spacers front, 10mm spacers rear
225/45/17 and 205/45/17 tyres
Interior:
B&M shortshifter
Factory Monsoon Sound system
Bride Low Max Vios III seats with hand built and machined seat bottoms bolted to the floor (a little mix of JDM and euro, proud to say im the only on in Calgary and for all I know Alberta with these seats in a VW)
VDO Boost Gauge with perfect match LED coloum mounted
C pillar Stress bar
Rear seats out
Exterior:
20th Headlights
Badgless grill
Eurogear CF hood with no hood notch
blacked out side repeaters
Car debadged
Europlate
Misc:
I have winter wheels and tires for it. Tires have 80% tread left on them, mounted on factory GTI wheels. I have the adjusting wrenches for the coils aswell to lift the car back up for winter. If buyer is interested I can set the car up for winter for them for free.
Car is in good shape. Meticulously cared for. For those who know me, they know this car gets washed every single day, and wiped down. Oil changed every 2000km's with synthetic. K&N filter cleaned every month. The front bumper could use a re spray in the spring, but other than that, there are no major dings and nicks. As well as the front strut bearings could use replacing in the spring.
Battery is BRAND NEW as of a couple of days ago. Optima Red Top
Im asking $11,000. I figure this is a good price. The car is solid. You will not meet anyone else who has cared for this car like I have.
Pm me or call 403 988 6386
Will consider trade for small truck or MK4 GTI VR6
Motor:
KO4-001 Turbo
Eurojet boost hoses
AutoTech CAI
APR software
ECS N75 Race Valve
Chassis:
Interior:
B&M shortshifter
C pillar Stress bar
Rear seats out
Exterior:
20th Headlights
Badgless grill
Car debadged
Europlate
Misc:
