Up for sale are 25 MK4 Tuner lugs used for about 2 weeks the key is in perfect shape the threads are 30mm long so a bit longer then stock. The stud conversion bolts (All 25) were used for about a month, you will require 12mm x 1.50 RH nuts to fit your wheels once you installed them. Only reason i took them off is becuse i went with a 15mm spacer and i had to get longer ones.
Asking 50$ for the tuner lugs and 50$ for the stud conversion.
Best way to contact me is via email its pete.dixon.mb@gmail.com
located in edmonton won't have a phone till friday since i lost my iphone :(
thanks for looking !
