MKIV 1.8t used brakes.
  • MKIV 1.8t used brakes.
    Wasn't certain anyone would be interested, but its worth a try.
    I have oem rotors, and what I believe to be oem pads for all four corners with decent wear left. Not by any means new, but if someone is looking to do a quicky brake job on a daily (if you don't wanna spend the extra or whatever other reason) these will last for quite a while yet. Sensor is intact for drivers side front rotor. Pics to follow.
    Lets say, 90$ obo takes the whole shebang?
    Re: MKIV 1.8t used brakes.
    is it fair to assume that mk4 breaks from a 1.8t will fit on a mk4 2.0?? if so i'm interested
      I believe they are not a fit but not sure.
        rears will fit fronts won't
        Alex Dewar
        2013 T-Red GLI
        sigpic@BuckyVW
        Old
        03 Golf CL
        2.Slow
          Sorry it took so long to get pictures, here you go.
          I only took pictures of two rotors, one back pad, and one front bad. The matching pieces are all in pretty much identical condition. I didn't clean them, either.
            Iirc you have to change the front knuckles as well as the brakes for work on a 2.0
              bump, would like these to be gone.
                still have these, send me any reasonable offer.. they aren't doing me any good sitting in boxes!
