FS: H&R 12mm Spacer Pair (1 set available)
  • FS: H&R 12mm Spacer Pair (1 set available)
    BLOW OUT!
    1 pair available
    5x100/5x112 57.1 tapered hub for OEM & BBS wheels.
    Part # 24255571
    Special Eurodrivers members only pricing @ $50 for the pair. Bolts not included but can be provided if required.
    Tunerworks Performance Inc.
    Re: FS: H&R 12mm Spacer Pair (1 set available)
    Decent price!
    TWO TON ENGINE LIFT/CRANE FOR RENT
    PM me if you need one!!
      price with bolts????
      Current
      04 GLI low and slow OG
      Past
      00 Jetta 1.8T OEM+
        Depends on the length, if you have OEM wheels with stock bolts and only need longer bolts for 2 wheels you are looking at $110 for the spacer + bolts.
        If you have aftermarket BBS wheels or are making these work with other wheels, bring in the bolt you are using currently and we will get you longer bolts but I cannot quote until I know the length.
          PM'd everyone back.
            Bump last set!
              Sold!
