Hello,
Selling my 2002 Jetta GLS 1.8T
179 XXX km
Fully Loaded, sunroof, heated mirrors, everything except leather
I am the second owner; the first had bought the car here in Edmonton and then moved to Calgary. Maintained at the VW dealership by the original owner (everything down to light bulb replacement). Bought it with 69 000km 5 years ago.
Since then had the car maintained at Dubsport, followed the recommended maintenance schedule since I had it. Had the timing belt replaced on time (including the water pump). All coil packs replaced around 80 000km. Oil changed religiously with a manufacturer recommended brand or better (to keep that turbo going strong). Used it as my daily, had I parked for almost a year when I went to Ontario 2 years ago, then used as a daily again for commuting to the airport and back (that’s why the higher mileage, its 50km one way to work, but its hi-way).
Recent maintenance includes: New tires bought 1 month ago
New breaks installed last fall (cross drilled)
New tie-rod ends 1 month ago
New upper strut mounts front and back 1 month ago
Sway bar bushings replaced last year
New magnaflow turbo back exhaust (installed by
Dubsport so it has warranty), also 1 month ago
List of modifications (tried to keep it clean, simple and reliable):
Suspension: - KYB AGX struts with dampening adjustability
- H&R race springs
- H&R rear sway bar (with upgraded mounting brackets)
- Cross drilled breaks on all fours (with painted red
calipers)
Power: - Turbo back magnaflow exhaust
- Autobraun Short ram Intake with BMC filter
- Samco Turbo inlet pipe
- Samco intercooler hose kit
- Forge diverter valve
- 4 bar fuel pressure regulator
- Revo stage 2 software
Interior: - Stewart warner A-pillar boost gage with pod
Euro switch with rear and front fogs relayed with OEM
parts
- Applied suede on the roof liner and pillars after my
sunroof met a nasty rock on the hi-way, also replaced
the sunroof and rails (greased them good).
- Satellite radio unit included and cables already ran
Exterior: - GLI headlights with HID kit installed in the fog lights
only
- 4 Motion lip
- Europlate
- 18 inch Spyn Autobahn wheels (discontinued)
Selling because I want to buy a diesel, work at the airport and live on the North end
If you would like to see the car you can email me at mix_mdj@hotmail.com
Asking $11,000 OBO
179 XXX km
- H&R race springs
calipers)
parts
only
- 4 Motion lip
- Europlate
Asking $11,000 OBO
