SOLD!!
Well… it’s that time folks. The car has been an absolute blast to own, but it’s time for something new in the stable. It’s not going to be cheap, but it’s worth every penny. I just want to get out what I put into it, so I’m asking $65,000 obo. Ok, maybe not, but that’s seriously got to be close to what I’m into it for over the last nine years; no expense was spared in my attempt to take good care of this car. Many of you know the car personally, as it’s been out to a ton of meets and shows over the years. If you have any questions about it, please PM or email me and I’ll be more than happy to get back to you. It handles very well, and with the turbo and 6-speed conversion, it’s incredibly quick, responsive and fun to drive.
1999 MK3 GTI 12v VR6 Turbo
Asking $18,900 o.b.o.
NOW $15,900 o.b.o!!
NOW $14,500 o.b.o!!
NOW $13,500 o.b.o!!
NOW $11,900 o.b.o
NOW SOLD!!
Please keep to serious offers. No random test pilots and no trades.
Thanks!!
Rob
Email: jrobertwatts@gmail.com
Some details (I’m sure I’m missing some things….as I think of them, I’ll add them…)
Engine/Performance:
(All internal engine block worked performed by Calgary Autoworks for turbo install – Summer of 2008)
(This started as a Kinetic Motorsport Stage 3 turbo kit, but before it got installed, some things were sold off and some custom upgrades were added.)
-SPA 7000H Turbo (T3/T4, .63 ar, 4” inlet)
-Kinetic Motorsport VR6 Manifold
-Polished C2 Shortrunner Intake Manifold
-TiAL 38mm Wastegate
-Turbosmart Vee-port Blow-off Valve
-3" Stainless Steel Downpipe (Heat wrapped)
-Braided Oil Lines and Oil Pan with fittings
-Silicone Hoses and Stainless Steel T-Bolt Clamps
-8.5:1 Stainless Steel Head Spacer
-ARP head studs
-ARP rod bolts
-42# Bosch Fuel Injectors
-C2 Motorsports 42# Software
-Walbro 255lph inline fuel pump
-custom 2.5” intercooler piping (by Calgary Autoworks)
-18”x9”x2.5”, front mount air/air intercooler (2.5” diameter for both inlet and outlet)
-2.5” Jetex stainless steel exhaust system (from downpipe back, 1 muffler at rear)
-engine block painted black
-deleted cat
-deleted secondary air injection
-had to remove A/C for turbo install (with the larger turbo inlet, the A/C lines wouldn’t fit)
-billet aluminum MasonTech waterpipe (crackpipe)
-low temp (70 degree) thermostat and new thermostat housing
-low temp (75-82 degree) fan switch
-shorter length serpentine belt (due to A/C delete)
-timing chains done with rebuild
-rear main seal done with rebuild
-All other bearings/rings/gaskets, etc… replaced when motor rebuilt for turbo application (Summer 2008)
-new battery (May 2009)
-oversized red spark plug wires (from Concept-1 VW)
-ATP Turbo oil catch can
-AFE re-useable air filter
-VF Engineering front and rear engine mounts
-VF Engineering transmission mount
-the required quota of black zip-ties
Transmission:
-Quaife Synchromesh, 6-speed, close-ratio gearkit (full transmission originally assembled and purchased from HPA Motorsports)
-Quaife Limited-Slip Differential (originally purchased from HPA assembled with the above transmission)
-Spec Stage 3+ Clutch (new in late Fall 2008) (No track use since install)
-Autotech lightened steel flywheel
Suspension/Wheels/Brakes:
-K-Sport Kontrol Pro Coilovers (Height, Rebound & 36-way Dampening Adjustable) (installed spring 2009)
-Neuspeed Front Upper Strut Tie Bar
-17x7 Mille Miglia M11 Wheels w/ 205/40/17 Falken 512’s (70% front / 80% rear)
-8mm FK spacers (front)
-5mm FK spacers (rear)
-Zimmerman Crossed-Drilled Brake Rotors front and rear (just replaced front rotors – June 2009)
-PBR Ultimate Ceramic Brake Pads front and rear (just replaced front pads – June 2009)
Exterior:
-Smoked side markers
-Smoked turn-signals/fogs
-Smoked Angel-eye FK Powerlook Headlights
-Repainted the front bumper over the winter of 2008/2009 (No accident or anything sinister, just wanted to freshen it up from all the stone chips over the years…)
-FK De-badged front grill (The slats are painted black) (Spring 2009)
-3M Protection on entire front bumper and new grill after painting (Professionally installed by Fifth Ave VW)
-3M Protection on headlights / turn signals / fogs (Professionally installed by Fifth Ave VW)
Interior:
-Very good condition black leather interior with “puffy” doorcards. (approx. 60,000kms on the seats)
-Just installed new Redline Goods black leather shift and e-brake boots (w/ red stitching) (June 2009)
-Recently replaced steering wheel with OEM Driver’s Edition Wheel (w/ red stitching) (Spring 2009)
-AEM Air/Fuel Ratio Gauge
-Greddy Profec B Spec II Electronic Boost controller
-Autometer Boost Gauge
-Alpine iDA-X001 iPod head unit (USB stick capable)
-2 x 10” JL subwoofers
-Soundstream Amplifier
-Aluminum door pins
-Momo pedals
The Bad:
-Passenger front doorcard has a little ripple in the leather at the top.
-Fog light on driver’s side is cracked.
-Unfortunately, I had to winter drive this in the early years of ownership, so it’s got some rust bubbles starting in the usual MK3 Golf locations (rocker panel, rear quarter panel and hatch)
-Other than the front bumper and grill, it’s all original paint… so it’s got what’s expected for ten years worth of rock chips and minor scratches.
-Passenger side rear quarter has some slight scratches on lower portion due to someone scrubbing past it with their bumper in a parking lot years ago. (No dents, just surface scratches)
-Odometer is wrong. Currently on third instrument cluster (replaced at Northland VW and apparently the mileage cannot be set by the dealer on the replacement modules.) First one died with just shy of 99,000 km’s on it, next one died with just over 10,000 km’s on it, so if you add 110,000 km’s to the current odometer reading, you’ll be a little high, but fairly accurate. (The electrical issue that caused these failures was resolved.) Car currently has approximately 79,000 km’s showing on the odometer and is being daily driven (mostly on nice days) in the summer; some quick math shows that the body has approximately 189,000 km’s on it.
-Wheels are starting to show their age (Have been repaired/repainted by Andrej once a few years ago, but are a little marked up again.)
The Good:
-At Euroquake 2008 in Red Deer, dyno’d 392 hp / 344 lb torque at the wheels. (@ approx. 18psi)
-Award winner!! It took home the dyno-queen title for its above performance at Euroquake and also won second place that year at the same show for the MK3 category. A few years ago, when the car was still supercharged, it won the Das Volks Show drag racing title at Race City.
-Yes, the car has been tracked and yes, it has been driven the way a car like this should be driven to be appreciated… BUT, it has also been very well cared for and well maintained.
-Oil and all other fluids checked and changed regularly.
-Since I’ve owned the car, I’ve only used synthetic oil.
-Claybared and waxed about a month ago.
-Calgary Autoworks has done any and all of the recent service on the car and know it very well inside and out.
-I’m the second owner and I’ve had the car since June 2000; purchased from South Centre VW with approximately 15,000 km’s on it.
-Car is ridiculously fast and fun… it will definitely be missed, but after a little over nine years, it’s just time for a new toy. Let’s get it to a good home.
Now, some pictures...
Outside:
Inside:
Engine/Exhaust:
Wheels:
For more pictures, you can reference the turbo buildup thread from last year for a few...
http://www.eurodrivers.ca/forums/showthread.php?t=14456
NOW $15,900 o.b.o!!
NOW $14,500 o.b.o!!
NOW $13,500 o.b.o!!
NOW $11,900 o.b.o
NOW SOLD!!
Thanks!!
Rob
Engine/Performance:
-ARP head studs
-ARP rod bolts
-deleted cat
Transmission:
Exterior:
Interior:
-Aluminum door pins
-Momo pedals
The Bad:
The Good:
Outside:
Inside:
Engine/Exhaust:
Wheels:
