MKIV Keyfobs
  • MKIV Keyfobs
    Not sure what you can do with these so $20 for both.
    edit I guess you can use the button batteries
    SOLD to Kordain
    drive green ||
    Re: MKIV Keyfobs
    Do they still work, why are you getting rid of them, could these be reprogrammed?
      Re: MKIV Keyfobs
      yeah they work. I programmed them to my car and it would lock/unlock the car fine. You can't start the car though because of the immo3 chip. I can't give you input on reprogramming but probably someone else can chime in? Selling because I don't need 4 keyfobs and I don't know what to do with these...
      drive green ||
        Re: MKIV Keyfobs
        dealer can reprogram them for you
        should work on audis too.. just swapt he plastic cover for the audi one if you wanted to..
          Re: MKIV Keyfobs
          Sweet, thanks Ryan!
          drive green ||
            Re: MKIV Keyfobs
            So after the dealer reprogrammes it, can the key start the car? Or is the programme strictly for opening and locking of the car?
              Re: MKIV Keyfobs
              I believe so. It can open the car without having to go through the dealership but to program the immobilizer you need to get the chip reprogrammed. But these are not blanks. .. They have been cut
              drive green ||
                Re: MKIV Keyfobs
                they should be able to start the car.. i got new keys with my allroad that are cut but i don't think the cutting means crap on these cars its all to do the the chip in the key
                i even received a plastic emergency key that still has a chip in it.. its litterally just the blade part of the key all plastic
                dealer programs it and matches it to your imobilizer using a secret key code (SKC) generated by them using your vin and cluster..
                  Re: MKIV Keyfobs
                  SOLD,
                  Ill take em thanks see your pm
                  Eric..
