FS: ALH Racepipe (EGR delete)
  • FS: ALH Racepipe (EGR delete)
    Make me a reasonal offer. Pics to follow.
    2012 VW Jetta GLI
    Re: FS: ALH Racepipe (EGR delete)
    Here are the pictures.
    2012 VW Jetta GLI
      i assume this is for stock intake manifold? just let people know... cause there is also a pd150 race pipe.
      2002 VW Golf GT TDI
        hmm, that thing looks cool. GL with it.
        James
        mk4 wagon
          Yes for the stock ALH manifold.
          2012 VW Jetta GLI
            Conditionally sold. Pending meeting.
            2012 VW Jetta GLI
              I have decided to keep it. For now.
              2012 VW Jetta GLI
                your intake and head will still carbon up.(no brainer)
                but the bright side is your egr won't stick shut.
                you should've made your own\ ! Madd Max Style it would be way cooler.
                i'am building a couple now.
                anybody want to try a prototype ???
                  How is the intake still going to carbon up without the hot EGR gases? To create carbon you need oil (Which can come from the turbo or the CCV(which he has removed as well)) Heat, and soot. Now I understand that there is some heat, but the soot aspect of the equation is totally removed. Soot needs to be mixed with the oil, add the heat and you have carbon. The heat in the intake will not reach nowhere near the temp needed to change the oil properties. I pulled my racepipe off after 50,000 km's and there was a small oily film, but nothing else.
                  Ben
                  2016 Ram 3500 Laramie
                  2000 Jetta TDi, Dead and removing parts
                  2005 Passat Wagon TDi, 310,000 km's and counting, BSM delete done....Trans died going to replace
                  Her's
                  2016 Toyota Highlander XLE Pearl White
                    After doing some research on TDIclub I agree with Benjamin. I am going to probably work the racepipe into my turbo upgrade.
                    2012 VW Jetta GLI
