Asking $5000 FIRM On with the info.....
Contact me via: Akalynchuk_07@hotmail.com
Specs:
-95' GTI VR6
-Sequoia green
-198xxx kms
-Manual Tranny
-No Rust! (At all!)
-Power Windows / Sunroof
-Originally had heated seats (wiring / switch still there)
Mods:
-Neuspeed exhaust w/ borla muffler.
-Cold air intake
-Fk 35 / 40 Cupkit
-1/2" Spacers in rear
-Seat front lip
-Badgless Grill (Painted)
-E-Code headlamps
-Smoked sidemarkers
-FK Smoked turns / signals
-Stubby antenna
-10" Polk Audio Sub w/ amp
-Pioneer Headunit
-Yonaka "Ronin" seats
-Headliner / all surrounding (upper) interior panels dyed black
-Rear seats have been removed and car has been converted into a 2 seater with the addition of a custom sub-floor, could easily be converted back.
-A bunch of other little stuff I've forgotten
Repairs Done Since I Have Owned:
-Spark Plugs
-Oil Changed every 5000kms (Synthetic 10 w 30)
-Water Pump
-Thermostat
-Thermostat housing and all applicable gaskets
-"Crack" pipe
-P/S Steering rack
-All engine mounts
-Transmission mount
-Clutch / Flywheel / Pressure plate and all applicable seals (Less the 6000kms on new clutch)
-Clutch Slave Cylinder
-Timing Chains and all applicable seals and guides
-Oil Cooler Seal
-Oil Pan and gasket (Bottomed out a little bit, no real damage other than the pan and pump)
-Oil Pump
-New Sideskirts
-Probably tons of other little stuff I've forgotten about
-New windshield
-Driver side and Passenger side window regulators
-Driver side wheel bearing (front) ( 01/16/08 )
-New strut mounts ( 01/16/08 )
Specs:
-95' GTI VR6
-Sequoia green
-198xxx kms
-Manual Tranny
-No Rust! (At all!)
Mods:
-Cold air intake
-Fk 35 / 40 Cupkit
-Seat front lip
-E-Code headlamps
-Smoked sidemarkers
-Stubby antenna
-Pioneer Headunit
-Spark Plugs
-Water Pump
-Thermostat
-"Crack" pipe
-P/S Steering rack
-All engine mounts
-Transmission mount
-Oil Cooler Seal
-Oil Pump
-New Sideskirts
-New windshield
