Tornado Red
202k
Full Recaro interior, in very good condition
ABS
A/C (WORKS! But slightly low on R-12 charge)
Power Windows, Mirrors, Door Locks
Cruise Control
MFA
Ski Bag
"Fancy" Stereo system w/ door pocket speakers
Techtonics Exhaust
Steelies with winter rubber w/ ~35% tread
& BBS RA's with Toyo Rubber w/ over 50% tread
Recent work:
Timing Belt and Tensioner
All Belts
TT Exhaust
RF Wheel bearing
Valve Cover Gasket
Alternator (used)
Starter (used)
Thermostat
Upper, Lower Rad hoses, overflow hose & new coolant
Tranny Mount
Spark Plugs, Cap, Rotor
Air Filter
Fuel Filter, Injector Seals & Fuel System Flush
Negative Battery Strap
Hall Sensor
Battery
The not so goods:
Windshield rust
some spots of rust, dents, scuffs, peeling clearcoat here and there
needs front struts and strut mounts
front brakes will need to be done sometime in the next year
Cam Seal is leaking
Asking $4,700obo. Can be lower without the BBS's
nbracko@shaw.ca
Nathan Bracko
202k
ABS
Cruise Control
MFA
Ski Bag
Techtonics Exhaust
Recent work:
All Belts
TT Exhaust
RF Wheel bearing
Valve Cover Gasket
Alternator (used)
Starter (used)
Thermostat
Tranny Mount
Air Filter
Hall Sensor
Battery
The not so goods:
Windshield rust
Cam Seal is leaking
nbracko@shaw.ca
Nathan Bracko
