So my turn signal clicker has a mind of its own. it will just be randomly clicking when ever it whats to. The signal lights dont turn on, but just the clicking sound some where in the dash go nuts some times. Any one had this problem or know a fix?
Turn signal clicker gone crazy!
Re: Turn signal clicker gone crazy!
this just happened to me.. there is a thread. 1st thing I would try is to spray a bunch of electrical cleaner in to where you signal light arm meets the steering column. This suggestion was made in the thread I started, and it has been working for me since i did that. Short of that, you may need a new multifunction arm thing. Try the cleaner first... its cheap.Stefan
As also mentioned in that thread there is a recall on the hazard relay for 2000-2002 Golf/GTI and Jetta. The dealer must replace it for free.Jeff
Had the same thing last year, the hazard switch is a recall and can cause it but mine was in the switch itself, actually took the switch apart and cleaned the contacts, hasn't been a problem since, there was excesive build up of grease on the contacts, wouldn't recommened taking the switch apart if you don't know what your doing though.
i had already had the hazard switch done, but yeah.. either way, get that done if you haven't.Stefan
9 Times Out Of 10: Signal Arm1) 2007 Candy white MKV GTI. DSG, votex kit, 19" Privat netz, tinted tails, smoked side markers & mirror signals, 20% tint, TT stubby, APR sport 3" turbo back exhaust, ABD stage 2 cold air intake. GONE.
2) 1993 Green Corrado VR6. ABD intake. FK Silverline coils, Zimmerman cross drilled & slotted rotors. GONE.
